Fuse ?
Fire34
We went for a ride the other day and when we went to honk the horn at some neighbors, nothing. Just got done looking in the owners manual and could not find which fuse it might be. Thanks guys
Dave
Not sure...
on my 2012 RS the horn fuse is a 10A located at F2 but usually they are grouped. In my case the horn, clutch valve selenoid and the diagnostic link connector are on the same fuse. Hopefully someone with the shop manual can get you the location. Otherwise just check them all to see if any are blown...check the horn connections....:dontknow:
20 amp fuse, position F5 in the right fuse box. The horn shares the same fuse as the air suspension. It is highly likely that your suspension air compressor has gone bad and blown the fuse.
While on the subject, I'm thinking of adding a second horn for a more penetrating dual tone. Anyone know if the horn circuit is on a relay? And where are the fuse box(es) located on a F3L?
Remove the 4 pushpins on the bucket in the front trunk and pull out the bucket to access the fuse boxes.
Thanks a lot - much appreciated. I didn't recall if that was in the manual or not, even tho I did read it cover to cover. Reading is one thing, but remembering is another. Hmm...I forgot where where this was going. :)
