Frunk leak
altonforbus
Anyone have a problem with rain water getting in the front trunk, especially when just sitting outside in the rain? Looking for answers on stopping the problem.
Double check that the rubber gusset is seated properly. In 99% of leak situations, the gusset is the problem.
Rubber gussets good. Used some color cut and smeared on the inside with liner out. It looks like the seam above the fuse panel is where it is leaking. Dry and no color change between fuse box seam and to rubber seal.
