frunk adjustment
randyandsandy74
Can anyone tell me if there is an adjustment to the frunk lid on a 2012 RT limited? Mine seams to be a little higher on the left side and lower on the right as you are looking from in front of the bike. Is the latch the only adjustment? Thank you all in advance :banghead:
Frunk Lid Adjustment
From a guy that just rebuilt a wrecked frunk in the parking lot of the Lamplighter South during Spyderfest, there are adjustment possibilities. But making sure the gasket is properly seated all the way around should come first.
Between the four 6mm (10mm hex head) bolts that hold the frunk lid to the hinge and the two T30 Torx head screws that hold the other side of the hinge to the frunk, the fit can be adjusted. Not to mention a few choice four letter words when you zig instead of zag and have to start all over again.
The latch adjustments are only for adjusting it, after you get the lid to fit right.
There's a pretty good explanation in the service manual under Chassis>Body>Front Cargo Module. And IMHO, if you are going to do virtually anything on your Spyder yourself, invest the $20 or so bucks on a manual.
Mike in KY
adjustment
Thank you Metman and Trikermutha for your advice will let you know how it comes out. Again thank you very much. This forum is awesome.:yes:
