front tires
Seek and you shall find...
A search will net you a mind boggling array of tires and opinions...as for myself I have found no problem with the oem kendas. Long lastingcand great handling. That's my experience....:thumbup:
FRONT TIRES
Replacement tires for front of a 2014 RT-S, What brand and size are you people putting on ??
.I could spend an hour talking about front tires...... but in the end it will all boil down to " EXCELLENT FRONT ALIGNMENT ". ie Rolo / Tru-Trac Lazer alignment. I've had super sticky front tires and that just caused the " NANNY " to kick in more often.....So lesson learned .....Mike :thumbup:
+1 to the Kumhos in the 155/60-15 size on our 15 RTs
We are now Kumhos all around with the 225/15 Kumhos on the rear getting around 20,000 miles and the front Kumhos projected at around 40,000+. Here is a pic of the fronts after 20,000 mi compared to the new ones. Wife loves the roll and handling at 17 psi cold, so the new ones go on my bike this year. DSCN1593.jpg
I have been doing some searching for Lazer alignment in my area there don't seen to be any so to me its all about tires.
Plan on seeing Squared Away or make trip plans to attend a Spyder Event..
Highly recommend getting a check-up on the alignment when you get a chance. We have had ours aligned but probably will get them checked again as the miles roll by. Glad we have had an initial ROLO alignment. Any feedback on how often others get their alignment re-checked?
OEM's
I agree with Chupuca....I have no issue with the OEM's....at 16k on current and lots of rubber left. I run the OEM on rear until I replace than I have gone with the Khumo Esta...but when I get to the rear I always check here and make decision then. But for front's...when these need replacing I will go OEM.
HANKOOK
I'VE DONE KUMHO's, ACTUALLY I THINK I WAS THE VERY 1st TO MOUNT ONE ON A SPYD3R BACK IN '09....
I'VE HAD THEM FRONT AND BACK SINCE... STILL HAVE A KUMHO ON THE REAR OF MY F3, IT'S THE 2nd ONE ON THIS SPYD3R...
I COULDN'T FIND THE KUMHO's FOR THE FRONT THAT I HAD MOUNTED ON THE 'RS' I HAD, SO I LOOKED FURTHER, AND SETTLED ON THE HANKOOK's.... I NOW WILL LOOK AT THE HANKOOK's FOR THE REAR AS WELL.... BTW, EVEN WITH THE BIGGER SIZE UP FRONT, I STILL HAVE PLENTY OF CLEARANCE BETWEEN THE TIRES AND FENDERS....
DAN P
SPYD3R
I am running Continental Contiprocontact size: 165/60R-15 on the fronts. Put on this year( original miles on the Kenda's were 12, 807) I now have 3,193 miles on the Continental Contiprocontact. I have a 2014 RTS-SE6. Spyder handles excellent in rain.
Here is are some pictures of the Continental Contiprocontact tires: New Front Tires ( Continental) 014.jpg New Front Tires ( Continental) 009.jpg New Front Tires ( Continental) 013.jpg space between fender/and my finger. I am running the Continental Contiprocontact tires @ 19PSI. Deanna
DITTO
The 155 is what I ran before trying the 175. As good as the 155's were the 175 is a whole step up in handling:ohyea:
I COULDN'T AGREE MORE.... :thumbup:
I ADDED AN 'RT' SWAY-BAR TO MY F3, WHICH ADDED STIFFNESS, BUT THE 175's JUST COMPLETED THE PROCESS TO MAKE THE HANDLING JUST ABOUT 'PERFECT'... :firstplace:
DAN P
SPYD3R
I've got the Federal Formoza in the stock size on my 2014 RT and I love them. Great handling and I should get really good mileage out of them. Available at newegg.com or ebay
I took a set of Kendas off and the handling difference was amazing with the Formozas
Tires
What pressure are you running in those?
DAN P
SPYD3R
