groundeffect
Registered User
Hey guys!
So, I went out on an errand run the other day (a 150km run for milk and bread
). The steering felt a little washy and needed more force in the turns. I pulled over for a closer look. The tire treads were fine, no nails, so I looked further to the side wall where I noticed some cracks… lots!!
On looking closer at what looked like dry rot cracks… wasn't, couldn't be. I ride everyday, so these tires haven't been siting for longer then a couple days, ever. They had just over 11,000km on them, but only the front right tire had the issue.
I grabbed a bottle of water from the trunk and splashed some down the side wall looking for a leak. Down on one knee with my ear close to the tire I heard some hissing and loads of tiny bubbles from from all of the 8-10 cracks!! You know that sinking feeling in your stomach when you know something is wrong… yeah, big time!
Not thinking I needed a tow just yet, I started towards the nearest gas station with an air pump. Precious air pressure was escaping with every rotation and bump I hit. I knew with every sharp swerve and turn that leaned on my right front tire the cracks grew a size or two.
Easing through the downtown core at near rush hour I finally found a gas station that didn't have an "out or order" sign taped to it. Tire pressure is between 15+/- 2 psi by spec, and I've always run on the higher end at 17psi. I blasted it up to spec at 17psi and motored towards home along a route with other stations along the way.
I had Ride-On in both tires, it didn't even get a chance to work since it only works on the treaded parts of the tires, not damaged side walls as in this case. In the end I had both front tires replaced with new ones as a set, even though it was only the right front tire (with 11,000km on each) that had the cracking issue. I have no idea what caused the cracking and the tire was not covered underway warranty. I hear tires are simply not covered, period.
(Image of a few of the cracks attached - note the gold dots on the tire is a marker dot - me tracking the expansion of the crack)
All ok now with new front tires! :thumbup:
