Front tire mount 2014 Rt
duke50
Can any tire shop mount RT tires? Dealer wants $130 labor fronts. Trying to save $$
Pick one of your choice and ask. The Spyder rims should fit. Balancing is a different issue as I understand. The spindle on some spin balancing machines is too large to fit Spyder wheels. I may be wrong.
Took my new (car) tires and wheels to Costco. Total cost for mount and balance was $30.16 including taxes and disposable fees to put the Kendas in the trash where they belong.....
Kendas
Took my new (car) tires and wheels to Costco. Total cost for mount and balance was $30.16 including taxes and disposable fees to put the Kendas in the trash where they belong.....[/QUOT
:agree:, Kendas are no longer welcome on my Spyder. The problem, that's all my dealer will put on
SPYDER WHEELS
Since they are very close to the small Honda wheels any shop should have no issues ....the comment about not balancing is for the REAR wheel only .....the front wheel hole is not an issue ...... Mike :thumbup:
I went to a few big tire stores here in Las Vegas and they could mount but not balance my front tires on my 2016 F3L. I had to bubble balance them at home with a Harbor Freight unit. I also used centamatic balancers too.
Can any tire shop mount RT tires? Dealer wants $120 labor fronts. Trying to save $$
Duke, Check with the two local motorcycle shops/service locations to see if they can do it. They likely have the smaller spindles needed for balancing. And, I bet for far less.
File's Custom Motorcycle Services
Motorcycle Repair Shop
Pocahontas, IL · (618) 669-2639
Jim's Custom Motorcycles
Motorcycle Shop
Highland, IL · (618) 791-8531
Then ... What they said....
Any tire shop can dismount and mount the front tires. As mentioned many tire shops cannot balance them. Spindle size is not an issue for the front. It is the hub size. The rim center hub is too small to fit against the machined surfaces of the balancer hub. Adapter is needed and available from the balancer maker. But is an extra that most shops will not get unless they see a big enough demand.
SPINDLE VS. HUB SIZE
Thanks for this clarification .... I have had my front wheels balanced at a few different places ( in Vermont ) and they all were able to do it......who knew :dontknow:.................Mike :thumbup:
