Front Spring Stiffeners install and adjustment
A bit of an update.
I used a Pittsburg through hole socket set (Harbor Freight), with an 11/16 socket for this install. I found the shorter length/angle of this socket set worked better for my knuckles... this is almost the same as the box end ratchet wrenches, but stronger, and with a little more reach.
These are not as pretty as what Ron has planned, but they are affordable and functional. I have them installed with Ron's sway bar, and I will only need an alignment to assure proper tracking.
My RT no longer grinds the front of the bike off on road heaves/cracks, and corners like my old RS. If you have the same issues, here's an affordable fix.
