Phyxius
GOS member (Girls On Spyders)
I know there are a billion threads on here regarding shock settings. Per suggestions I asked my dealership to change them from 3 to 5 when I was in for my 600 mile service. Most of the trip home (almost 60 miles) was on straight highways. The stiffer shock setting was VERY bouncy. I went out of my way to play on some backroads and the handling was better but still quite bouncy. Now, they also "adjusted" my tire pressure which I'm sure means they let out some air as I had them set to 18 fronts and 28 rear. With hurricane Sandy here it will be a couple days before I can play with it but I wanted to get some thoughts from you guys.
Should I:
A) Ride around as is for a while?
B) Up the tire pressure back to 18/28, leave shocks as they are and drive around a while?
c) Up tire pressure back to 18/28 and change front shocks to 4?
Basically, I'm wondering if upping the tire pressure will help even out the ride or if I just need to soften up those front shocks a bit?
Should I:
