Front Fender LED issue Help required
eddieshep999
I have RT Spyder SE6 2015 with the front fenders which have the front LED lights built in in the cross member which also has the side reflector and rear reflectors also built in
Mine has the Side reflectors & the Rear reflector changed to LED’s (the side indicators act as both indicator & running lights & the rear acts as both a running & brake light)
I need to replace the wires due to a breakage and need to access the wire underneath the cross member
Once I remove the fender how do I remove the cross member from the fender to access the wires
is it screwed to the fender or do BRP use tabs (I don’t want to break any tabs off)
Any guidance would be helpful
Photo of the type of fender I have fitted show the cross member
There's no need to remove the fender.
Remove the front wheel and on the underside of the fender there are five screws holding the cross member on. Remove them and the cross member lifts right off. Complete your work and reverse the process.
