Front brake noise
DriftersWay
On my 2012 RT with 280 miles I can hear front brakes making a noise. I jacked up and the tires will free spin but scrapes an 1 spot. This is the same for both front tires. Does this sound like warped rotors and could front end being out of alignment cause this. Thanks Butch
Alignment won't do it. Could be warped rotors, but if it isn't causing pulsating brakes it should be nothing to worry about. Could also merely be dirt/dust buildup. If it isn't loud or suddenly different, learn to ignore it. Motorcycles make a lot of odd noises. So do cars, but you often never hear them because you are farther away, often with the windows closed, radio playing, etc. JMHO
Scotty
Thanks Scotty. You was right, after talking to my dealer he confirmed that Spyder breaks will make noise. Seems the brake shoes will develop a small ridge and cause a squeal. He suggested to go in reverse for about 20 to 30 feet riding the brake and it usually knocks off the ridge. He showed me how and it did work. Just wanted to pass this on to you.
Noises..!!
You may also later hear clicking sounds when first applying brakes in reverse and forward motion. Pad hang on pins and shift positions. Best sign of a problem is overheating of calipers or/and disks...:ohyea:
