MercerLake
I have a 2008 RS and decided to Install a Voltmeter, used a POWER WERKS voltmeter as it has a bright blue display and mounts with a simple round 1.125" hole. What I found while following the wiring harness to find a convenient wire that is hot only with the key on is of most interest. The wiring harness at the relay/fuse panel at the front left just behind the Frunk had been rubbing on the adjacent metal. Several wires had the insulation chaffed away and were bare exposed copper waiting to short out. Likely on a "dark and Rainy Night" somewhere! Point being if you have the "Tupperware" off check all the wiring harnesses for chaffing on metal, save an inconvenient stop by the side of the road or a "FIRE"!:yikes::yikes:
