Found an inexpensive way to have GPS ball mount on 2014 RT Dash top
spyder-dude
I started with a RAM Mount Part number: RAM-B-272U for $13.00 available from a variety of online stores.
http://www.rammount.com/CatalogResu...d/082065077045066045050055050085/Default.aspx
Then bought a 3 pack of M5-80x20 Stainless Screw for $.62 from lowes: http://www.lowes.com/pd_424648-3767...96&UserSearch=882796&productId=4757855&rpp=32
Then I decided that I wanted to cover up the stainless screw so I bought a 2 pack of the black plastic caps: http://www.lowes.com/pd_137945-3767...29&UserSearch=881029&productId=3012661&rpp=32
You will also need a washer to match which I already had in my collection to put between the plastic cap and the screw.
Here is the finalized product.
Here is the finalized product mounted on my 2014 Spyder.
Figured I would post this to help people do this their selves and save some money on putting a Ram mount on their 2014 Spyder RT's! Total cost is under $15 or if you wanted to put two of them on it would be less than $30.
yep - thats the perfect place for them
I used that setup on my 2012 RTS
now on my 2014 I am using this setup:
on the left is a 7" x-grip for my iPad mini that I only use on long trips to act as my GPS
center is the GoPro mount
and right is the iPhone x-grip
thats the dash mount bar from jthornton here on Spyderlovers
Thank you for this! By chance do you know if this will work with the stock shield? Also,. could you measure the height that you have between the bolt and shield on the side that has nothing done to it? Also, include highest raised setting and lowest. Would like to see the clearance from your F4 and stock.
Thanks!!!
attachment.php
attachment.php
attachment.php
The more I think about this you honestly could get an extender arm from RAM mounts which would bring whatever you're mounting towards you a bit.
Great!
Thank you for this post. And including all the hardware part numbers that you used. Very helpful and cost saving.
:bowdown:
Did mod on my 2014, thanks.
attachment.php
attachment.php
Well I ordered 2 of the mirror mounts with part number from dealer and they were not quite the same. In stalled them complete with black cap but they were up higher. They did not hamper windshield in any way but I wanted them lower. So I cut them down and drilled new hole for m50 bolts. Good to go now! Thanks for info.
Phone multi mount on ram dash mount.
Here is photo with my multi mount on ram ball.
attachment.php
