Former RS owner, ready to pull trigger on 2013 RT
ScreaminMeanie
Wavey. :)
I haven't been around here in a couple of years. After two fabulous years of ryding with the love of my life, he was killed on his (two-wheeled) motorcycle by a drunk driver. :( Couldn't bear to be around motorcycles of any kind for a long while.
Time passes, the lure of the wind in my face is great, and I've been thinking pretty hard for several months about getting another Spyder. Been haunting the local dealer lately, and was about ready to jump on a leftover '13 ST, when the dealer got on trade a '13 RT-S. 870 miles :shocked: and with all the goodies I wanted, and a smokin' deal. I got a test ride this past weekend, and put a deposit on it.
So.....some questions/thoughts for all you extremely knowledgeable people.
I will be purchasing the extended warranty (something that was highly recommended when I purchased the RS, and I think it was money well spent).
I have asked the dealer to check on the status of the heat issue recall. This was a unit that they sold new, did all the service on, and was traded back in by the original owner (on an F3). Based on the incredibly low miles, in my mind it's unlikely the original owner brought it in for the recall work. I've told the dealer I won't take delivery of it until that work has been done.
Is there anything else I should be on the alert for? The heat issue recall is the only recall I'm aware of, but I realize it's not out of the realm of possibility that there might have been others. Also, I'm curious about any other common little fixes that others have done, as well as any recommended farkles. Personally, I can't think of any farkles it really needs, since the RT platform fixes all the ergonomic problems I had with my original RS, as well as adding all the extra storage, a powerlet, and heated grips.
I test rode because I was concerned I might miss some of the giddyup that the extra weight might take away from the 998's grunt power (~250 lbs more than the '09 RS). I could tell it wasn't as quick as the RS, but it still had more than enough power to put a big grin on my face. :D
You pose an interesting question. There is a fix now for the 2013 RT models. It involves new air scoops to be installed by the dealer as well as some additional insulation.
Those that have had the work performed, seem very happy with the fix.
The 2013 model year has had some bad press and because of that, the value of the 2013 has been hurt. A lot of BRP dealers will not even take them in trade.
New 2014's can now be had for up to $4,000 off and an extra 2 year warranty--this weekends TV advertising. If you cannot get at least $6K off the 2013 MSRP--I don't think you are going to be getting a good deal.
Personally, I would opt for a 2014 RT with the new 1330 engine given the current sale prices being offered.
Watch out for slick salespersons that may try to sell an overpriced (because of the fix) 2013 at this time. The resale market remains to be determined IMO.
Thanks for the reply. I should have provided a little more background, huh? Local dealer has no '14s in stock; next nearest dealer is 300+ miles away.
I went into this thinking I wanted a '14 ST, but several years ago when I was still on the RS, I was wishing desperately for an RT. Then, lo and behold, this one practically falls in my lap (and it's priced at $9K below MSRP), and it's hard for me to say "no"!
$9K is a really, really good deal below MSRP. Have the dealer do the factory update of course. I would also get a full print out of the service history, and maybe talk with the original owner if possible. There were some good 2013's and some really bad ones out there. Due diligence is my advice. I just would not want someone to get saddled with one of the "problematic" 2013's.
Likewise, I would not want to *be* that person saddled with one! On the ~50 mile test ride I took, it performed flawlessly, but I realize that could mean nothing in the big picture. I will definitely ask for service records and see if they are comfortable hooking me up with the previous owner's contact info. If all is well, they *should* be okay with it.
I'm sorry to hear of your loss...
But I'm glad to hear that you're making your way! :thumbup:
If this RT can get the recall work done on it prior to delivery; it could sure be an awful nice ride for you! :D
Good Luck! :2thumbs:
Hope this all works out great for you. You are a very smart buyer. :bowdown:
Once the recall work is done, the 2013s are quite the bargain right now. Much cheaper than a 2014 and much better bike than the 10 thru 12s. What once was to be avoided is now a bargain that will likely improve its resale value with time.
Ditto if "much better bike" means better handling than the 10 thru 12s. It is. If the "13" is an RT-S, then you will still have a slight "right hot foot" problem because of where you position that foot on the floorboard. That can be remedied.
Chris
My '14RT-S is my first Spyder and I have had no experiences with the Rotax V-twin engines. That said I don't want to rain on your parade but offer this suggestion: if your budget can handle it and you want an RT, a 300 mile or so drive to another dealer to test ride a '14 RT would be well worth it IMO. Even with the heat recall mods made you are buying older, some would say long in the tooth, technology. The 1330 engine, speed transmission and hydraulically operated clutch is a quantum leap in both performance and reduced maintenance cost. The 300 mile ride bringing a '14 RT home will have you very comfortable with it when you roll into your driveway. JMO. If you like the high reving V-twin, go for it! Good luck.
I can't remember which (entire) leg it was that got baked on the RS. Possibly both. ;)
My last long trip on the RS was 4000+ miles in 13 days, to Minnesota and back. About 1400 of those miles were side trips and self-initiated detours. Rode through 100F+ heat for several days, then day after day after day of rain and hail, slippery roads, road construction, you name it.
On the way home we did back-to-back-to-back 450+ mile days. That was when I was wishing so desperately for an RT. At one point in the trip, we got talking to a couple, him on an HD trike, her on an RT. My late fiancé brought up the problems I was having with the ergos of the RS, and the lady offered to let me sit on her RT. I declined, telling her that if I did, I'd probably end up bashing her over the head for her keys and riding the RT the rest of the way home. ;)
Ditto if "much better bike" means better handling than the 10 thru 12s. It is. If the "13" is an RT-S, then you will still have a slight "right hot foot" problem because of where you position that foot on the floorboard. That can be remedied.Chris
Yes, better handling, better brakes and now better cooling and fuel management.
Sorry for your loss
Wavey. :)
I just wanted to say I'm sorry for your loss.
HUH
$ 9,000 below MSRP on a Spyder that is very soon to be a two year old model with the OLD style engine in my book is not a Bargain....You need to know what the actual value of the purchase is after you drive it of the lot ....ie KBB, or NADA.....because that is what it's worth .......I paid $3400 under MSRP on my Brand new Spyder in April of 14.....................and there is a 14 RT-LTD on E-bay right now for $22,000.....JMHO.....Mike
WELLLLLLLLLLLLLLLLLLLLLLLLLLLLL
I just posted one I saw one for $ 16,299....a 2014 white RT SM-6, and they don't charge for shipping , handling , set-up, crate fee's etc.......Holzhaur Motorsports in Nashville Ill..........Mike :thumbup:
Hi Wavey. Love my 2013 RT especially now the "heat issue" is sorted as far as I'm concerned.
You asked about "farkles" - obviously no end of what can be done but the one single item that I added to my RT was a heavier Sway Bar. You will not believe the difference it makes to the handling of an RT.
Have fun and stay safe
2013 2014
Your are talking 2 very different bikes. If you can swing it the 14 has alot of advantages.
The 13 has very exspensive maintenance, low MPG. I believe 2 or 3 years from now the 3cylinder 6 speed 2014 resale will be much higher. If you plan on long rides the 14 will be more comfortable and less expensive . When we bought ours it was not for long rides, they are so much fun, smooth, comfortable we now go on long rides.
Kenn
Thanks for all the responses!
I simply don't know what to do. There are NO leftover '14s within a 3-state radius (that I can find), except for RS models. I understand the difference between the twin and the triple, and the associated maintenance costs. $9K under MSRP will buy a lot of services, and from what I'm seeing in other threads here, the '14s and '15s are starting to show up with some quirky stuff, too. Also, I specifically want the semi-automatic transmission, so that's even more limiting to my options.
My only other choice at this point seems to be the leftover new '13 ST at my local dealer, which has the same high-maintenance powerplant that many here are trying to shoo me away from, as well as its own host of known issues. At least it would have the full factory warranty (but I'd still want to purchase the extended warranty), and it's priced at $1K more than the RT-S.
The price difference between these two '13s available locally and a '15 is more than enough to price me out of the market. I'll spend up to ~$20K to get what I want, but not $30K.
I don't have the leisure to do a fly and ride to purchase one more than a couple hundred miles away.
:dontknow:
I have a '13 ST-S and love the V twin engine. If you can get the '13 RT for $9000 off MSRP and make sure they do the heat recall, then go for it. I don't think you will be disappointed.
:dontknow:
Buy from far away and have it shipped? A few have done this with good results. Others will have to come on and say who.
