cuznjohn
well after all the work i did mounting my horn yesterday, running the wired and doing a direct hook up to hear what it sounded like, the job could of been much easier. on the 13 rt the horn is on the left side of the frunk, so when i was thinking where it was i installed my new air horn on the right side and exposed because it is chrome. http://www.spyderlovers.com/forums/showthread.php?81264-where-i-decided-to-mount-my-horn,
so i just went out to do the relay hook up and i couldn't find the horn wires. i pulled of the left side panel and low and behold the horn in right inside and down a little. in the space where the horn is there is plenty of room to remove the stock horn and install the bad boy air horn. so what i did was to leave the stock horn connected and tapped into the wires for the relay. so now when i hit the horn both the stock and air horn will sound.
just wanted to help others so they don't make the same mistake i did and to show you where your stock horn is
