foglight help!!
shansmow
I purchased a foglight kit from someone and was installing them last weekend only to get to the point of installing the switch. No switch. I can understand the switch not being sent 'cuz if the person took it off it would leave a hole in the console. I've searched the parts list and couldn't find a breakdown for the switch so I called my dealer who told me the foglights are only sold as a set and you can't order individual parts!:gaah:
I saw Scotty's post about the problem he had when his console had to be replaced and I'm getting a really bad feeling about this...
Any suggestions/ideas on what I can use in place of the BRP switch or who I could contact to get one? And if you have suggestions on an alternate part please give me detailed instructions :D
Thanks in advance for any help you can provide.
BTW, this site is GREAT with instructions b/c I did the HID lights without any problems and the foglight instructions were just as helpful....until I got to the switch.
Dang. :gaah: I was looking for a post that I did a little while back. We installed a couple things using switches we got from an auto parts store. I'll look for it. One of the things was a second radiator fan installed behind the spider web on the right side. I actually like the switch better, as it is much obviouser when it is on or not. Not home till Friday - can find and repost then . . . .
Radio Shack has small, round plastic rocker switches that are similar to the BRP ones... like this one:
picture.php
duoh!
Ok, everyone say together "Rena is a moron." I went out today to look at the harness, etc. so I could see what kind of connector end I'd need to match up for the switch when I went to Radio Shack....well the switch is already connected to the end. :opps: What a moron I am! :shocked: I obviously got ahead of myself on the instructions and didn't really inspect everything. Duoh!:cus::banghead::banghead::banghead: But thanks ataDude and jnt for the information and I'll file that away for future reference. I guess this is why people like me should always just go to the dealer! Now it looks like I have another project to finish.....
Sounds like me when I was installing mine. During the step to attach the wires to the connector, I realized that I put the wires in backwards! :gaah:
I had to work the clip out very carefully to undo my mistake. That took about an hour of :cus: at myself! I was finally able to correct the error and get back on track without doing any permanent damage to me or the :spyder2:!
David
it is how we learn it does not mean that you have to give up>
