Fog Lights on F3-Limited
JimH
I bought an F3-Limited today, picking it up on Thursday - really excited. Can anyone share their thoughts on foglights on the F3-Limited? One of the machines had them installed and I was wondering about the utility of them. Could be an add-on in the future.
Thanks,
Jim
Fog light set was my first install on my F3L. Lamonster Garage has a great video and fog light set to purchase. It is basically plug and play after you watch the video.
Congrats on the new Spyder!
Lamonsters Fog light and ring combo is the best setup.
http://www.lamonstergarage.com/can-...ight-and-fog-ring-combo-motorcycle-lamonster/
Do not throw away the plastic blank that fills the hole now. I used a hole saw to cut out the opening and part of the remaining ring. It fills in nicely the space that is left open after the install for a more finished look. The inside part of the opening is what you are trying to fill in, from the top screw. screw in the top and the inside can be fastened with a piece of 3M double sided tape.
After the install, check your FM radio reception. If it is bad, Lamonster will send you a RF filter to fix it.
I have the TricLED LED foglights, no issues so far. Installed them with the TricLED headlights last week! (Avatar for reference) :)
another vote for the Lamonster LED fog lights. Cost less than half of the BRP unit, excellent quality, incredibly easy to install. As others have said, just follow the video and you will be done in 30 minutes. completely plug and play using the OEM harness already on the spyder.
congratulations on the F3L !
I bought the BRP fog light. I would NOT recommend them. Very expensive, almost impossible to mount without some serious adaptation. On our next spyder I will absolutely go with the Lamonster fog light. less than half the price of BRP and a very easy install.
John
