Roadster Renovations
What is everyone doing on these nowadays? Have one out and figured I would replace both.
I went with LED ( and as of late the headlights also) On the fogs, the right side is a snap ( literally ) ------- the left side NOT SO MUCH.What is everyone doing on these nowadays? Have one out and figured I would replace both.
...If you do the Fog lights .... take off the Frunk , it's a bit tedious ,,, but about 1/10 as tedious if you try and do it any other way. There is ZERO clearance, so if you don't get it perfect it ain't gonna happen ...... good luck .... Mike ...........PS please get the LED type :yes:Thanks!!
Interesting , I have the Tri-Clid LED headlights and no interference on either my XM or my normal FM radio ....sorry to hear this ...hope it can be fixed ..... Mike :thumbup:I went with Tric-LED head/fog lights. I had the right side burn out with the OEM bulbs last month.
I also have radio inference with the Tric-Led head/fog lights. Which I am working to get resolved. I have a 2014 RTS-SE6. I'll post the results next week. I am getting them changed tomorrow @ the dealership.
Deanna
If the frunk is OFF you can do the FOG lights with your eye's closed ...... I'm not kidding, it's that easy. .... The problem as I stated above is there IS NO CLEARANCE ......not for the light cover or the hands that do the work ........... Mike :thumbup:and when you DO take the frunk off it would be a good time for a"doc video
of fog light install and removing the frunk. hint, hint!:clap:--irv
LEDs are the way to go...if you buy Lamonts which I did, the headlight case you will need to modify.
I have been told that TRIC LED headlights you don't need to modify the headlight case.
Its not necessary to remove the frunk to replace the fog lamp bulbs. We do them all the time. I did have to watch Lamont's video a couple times to understand how he was accessing them but once you know how, they are not that hard. Especially if done while doing the head lamps as the required body panels will already be off.
Check out the videos at LamonsterGarage.com
