FOBO Tire settings
Front: 15psi +/- 2
Rear: 28 psi +/- 2
page 93
i set mine at 15 and let the app calculate the rest or you can set it manually.
Tire Pressures
Page 93.... Guess we better drop our pressures....put ours up to the almost max without reading the book,,,,OOPS:shocked::sour::dontknow:
ps.what (app) are y'all talkin bout???
Yea the book says 15 psi....
But if you look at the front tires it says Min 15 to Max 30 and the back says 30 psi. I am just trying to figure out what other people have there settings at.
Thanks for everyone's input
the manual states for the front it can be 15 plus or minus 2, so minimum 13 and maximum 17
for the rear 28 plus or minus 2, so minimum 26 and maximum 30.
for the FOBO TPMS YOU ADD 15 for the 2 from tires and 28 for the rear, it will automatically calculate the minimum and maximum based on a formula set in the app. If for some reason you don't like those numbers you can set it manually.
i keep my front at 16.5 and my rear at 29.
I set mine at 19 for the front and 28 for the rear.
