Floorboards to Pegs - F3 Limited
justsmile0808
Anybody swap out the floorboards for pegs on the F3 Limited? I'm really not a floorboard person - just want to make sure it's possible. I figured if you could go from pegs to boards...you should be able to go backward...no?
Hi what position are the floor boards in. My pegs are in position 4. I may be interested. Al
The boards/pegs have no impact on the position, Al.......the position is dictated by the length of your brake rod. The only thing you need to be aware of is that you need the board brackets as well as the actual boards, as the brackets are different to accommodate the length of the boards. ;)
Pete
I'm sure someone will correct me if I am wrong here, but it doesn't matter what position the board/pegs are currently in on the Spyder (with regard to fit on another unit). It was a general question - as I am looking to get out of my 2020 RT Limited and go back to my F3 home :-)
