Floor Boards by Jerry's Welding & Machine
Floor Boards
That looks great. I just sent Jerry an email to see if I could get that same set up. Thanks for passing that along! That's exactly what I have been looking for.:2thumbs:
Juice
Looks good for a one off but I would be real concerned about the leverage he has on the brake side. If this gives like I think it will and you slam into the back of a truck because you reduced your stopping distance I'm sure it's just a matter of time before he gets to check out if that liability policy he bought was worth the cost. That is if he has coverage.
Perfect! Just what I need!
This is the final mod I need in order to be comfortable. My hat is off to you Jerry, great work! I want both sides as soon as they are ready.
thought the same...:agree:
That bolt breaks your in trouble I used to have a 57 pan with a bolt like that in my rear brake linkage and no front brake hey I was 16 and stupid still stupid but broke that bolt twice not fun when your goin down a road with a culdasac (big circle)at end :yikes:
i hear you i'm still stupid also ...must be new england weather :D:coffee:
His email doesn't work. Maybe he changed it or gone out of business. I give up.
His phone works and email is correct. Must have been a problem with my server. Sorry
It looks like there is only one bolt attaching the pedal but there are two. The horizontal bolt is visible but there is another one which is vertical underneath. I've put 1500 miles on my spyder with the brake pedal and it's great! Spyderwoman
Look at the piece parts on the link and you can see the additional mounting gusset. I would still maybe add a corner support in the right angle of the brake pedal just in case.
But I like them alot.:2thumbs:
