First mods, Roadkrome luggage rack and Shad SH45 top case
Squanchkava72
View attachment 158062I took advantage of the warm weather over the weekend and got a Roadkrome large luggage rack and a Shad SH45 top case installed.
I read to clip a 1/4 inch slot out of the hole on the rear upper panel. I used dykes to score the slots then used a mini hacksaw to saw the 1/4 inch slots out. The little hacksaw made the job super simple.
I also read to swap the replacement left and right seat bracket bolts that come with the Roadkrome kit out for hex head bolts because they are hard to access after you install the luggage rack brackets. Instead of swapping to hex heads I used a small bit ratchet. This is handy little tool, it also worked awesome for removing the Tupperware bolts that are in tight spots.
This might save you some time, when you got to put the seat back on. Don't leave the seat and bracket at a 90 degree angle like when taking it off. After you have the luggage rack arms installed, you can't lower the seat back down from a 90 degree angle. I folded up some of the luggage rack cardboard to hold the seat up at the perfect angle to get the bit ratchet on to the left and right bolts while keeping the rear of the seat from getting pinched by the luggage rack arms.
The Shad top case is very nice, I still need to add the Shad back pad so passengers can lean back on it. I was going to go with an OEM luggage rack but I like the look of Roadkrome rack better and liked being able to keep the stock BRP tailpiece in place. Seems nice and sturdy too. They also make a smaller luggage rack and a passenger backrest.
