Finally, I got a brake! (Thank you, ISCI)
Pete Denzer
I've had several issues with my OEM brakes not being up to snuff. The tech at the dealership bled my brakes and hooked up to computer's BUDDS program as per shop manual as I watched. When it came time to measure braking pressure I had to STAND on brake pedal to bring all my 160 pounds to bear on it to generate the prescribed 508 psi at the pressure sensor. The tech did everything thoroughly using the manual, this was his first time at it and next time he will be faster.
I road tested the brakes afterward, had a harder (less spongy) pedal but no improvement in stopping distance (got it up to 60 by speedo on back road straightaway, applying brakes at reference mark, a "bridge ahead" sign, and measuring the results, it was all I could do to stop within 210 feet). Took the Spyder home, removed front pads and scuffed with sandpaper, took back to test site, improved braking registered 189 feet -- that's a balls-out full panic stop on a recently-resurfaced tarmac surface, which SUCKS, that brake/tire/weight combo should stop in much less that 140 feet.
Then I installed the ISCI handbrake system, complicated by my BRP extended passenger pegs, windshield clearance issues and Parkinson's-related spazziness, but I got it done all by myself, it took me a full day but I'm no longer a professional mechanic (though I have a great selection of tools from my 30 years-ago former career as a heavy equipment mechanic for Bethlehem Steel).
RESULTS:
Now when I put all my weight on the brake pedal, applying the handbrake afterward with only average effort from a medium-sized right hand forces the foot brake down even further, VASTLY IMPROVING STOPPING DISTANCE. To be honest, I haven't had a chance to get back to my secret test area, the road was having its bushy shoulders trimmed back today, but I'm sure my stopping distance will be much better. Most heavy cruisers (which out-brake sport bikes in 60-0 tests due to longer wheelbases and more weight proportionately over the back brake) can stop in 130 feet or much less from 60 mph, as can sport bikes risking "stoppies" and most cars with four-wheel disk brakes.
I carry a 100-ft tape in my trunk. I'm betting on 130 feet.
I showed the setup to the techs at the shop, all of whom are much heavier than I, and they, too, observed the added pedal travel afforded the brakes using the hand lever, though not as much as me. Part of this is ergonomic: Someone with a 36-inch inseam will have his lower leg at a sharper angle, allowing him greater foot movement and the ability to press down on the brake pedal further regardless of weight, so the improvement noticed will not be as much as me with my 29-inch trousers. My dentist, who rides, is a REALLY big guy, probably 300 pounds, managed to move the pedal pretty far with his size-14 right foot, but he still liked the handbrake addition. Everyone was impressed by the neat factory-installed look of the setup.
This is by far the most expensive addition to my 2009 SE5. Worth every cent, my biggest complaint is that it had to be done at all, which I lay at BRP's feet. "I don't see why they didn't do this at the factory," said my tech. "Or have a different master-to-slave cylinder ratio."
I don't remember how the manual spec reads, but normally any pressure on the pedal should result in the prescribed brake system pressures. Standing on it should not be necessary! Standing on it should not give the minimum test pressure, either. There is still a problem with your braking system, IMO. I don't carry a tape, but our Spyder will stop harder and straighter than almost any bike I have ever ridden. O fcourse many of mine are drum brakes, but it does as well or better than my R1100RT equipped with Brembos and ABS. Test data show the model is not top of the heap, by any means, but I have never ridden one of the sport bikes to compare. I'd run this up the flagpole again, or discuss it with Carlo. I still think you need brake system repairs.
I am glad that you are enjoying your ISCI Brake System. Also pleased that you feel that it was worth the money. Let me if know if we can be of help in the future.
ISCI Billy
:spyder2:
One thing I can say unconditionaly is that the Spyder braking system stops us (with or with out a passenger) far better than any bike I have ever owned or operated.
