Fault Code P0122 - 2020 RT. Is there a list of fault codes?
Snowhawg
Actually it's a 2020 RT. I got another limp home mode message today and the fault code was P 0122. Where can I find the list of fault codes for my bike?
A service manual is a good investment
The problem is probably this:
[table="width: 500, class: grid"]
[tr]
[td]P0122[/td]
[td]ECM[/td]
[td]First Throttle Accelerator Sensor (TAS) Short circuit to GND[/td]
[td]Damaged circuit wires, damaged throttle position sensor or damaged ECM pins.[/td]
[td]Make sure sensor connector is fully inserted.
Measure resistance from connector: ECMB-K1 to TAS-A (expected value: < 2 ohms).
Measure resistance from connector: ECMB-K3 to TAS-B (expected value: < 2 ohms).
Measure resistance from connector: ECMB-E1 to TAS-C (expected value: < 2 ohms).[/td]
[/tr]
[/table]
[tr]
[td]P0122[/td]
[td]ECM[/td]
[/tr]
[/table]
Thanks a lot Bert.
