fault code help
spyderbirds
Can someone with an RT shop manual look up the code c006c
i had a limp mode today with this and a couple of other fault codes.
shut off rt and took key 50 feet away for a minute and then restarted and limp mode cleared.
I thought i had my shop manual on the tablet i brought along to spyderfest. but i do not:banghead:
Thanks much!!
CB
According to my shop manual, the code is:
c006c ECM VSS CAN message Communication intermittent/erratic and/or External troubleshooting is not possible
plausability error checksum error check for communication fault
Frankly, that doesn't mean much to me but that's what the book says. Hope it helps.
Cotton
That really messed up. I'll post again in a slightly different format.
According to my shop manual the code is:
c006c
ECM
VSS CAN message - plausibilty error
Communication intermittent/erratic and/or Check Sum error
External troubleshooting is not possible - check for communication fault
Hope that's a little better and hope it helps.
Cotton
