Fault code C1290
Jcummins
I'm getting a VSS fault about every time I start the spider if it hasn't been started in a while. It's not running bad it seems to be okay but it made me check the software version which is apparently out of date comparing it to a post here about new software version. Also I check the fault codes and I got a c1290 that's been logged, what is that code for?
It might help if you told us the year and model of your Spyder.
C1290 is a VCM voltage failure
Possible causes
VCM supply voltage is much too high or too low.
VCM supply voltage spike glitch.
Service actions
Measure battery voltage with engine stopped
(Expected value: 11 to 13 volts).
Measure battery voltage with engine running
(Expected value: 13 to 14.7 volts).
Check connections on voltage regulator.
Check ground and positive connections on battery
Possible causes
Service actions
2020 RTL. I'll check those voltages.
I found a pdf online of spyder fault codes but this code was not in it.
Is there a complete fault code list somewhere?
Possible causes
Service actions
With that said by all means check battery connections & load test for good measure
I got a pdf a number of years ago, from whom I can't remember, that lists all the codes but does not include the possible causes and service actions. I got the information for post #2 from the Spyder Codes app on my iPhone that I I've had for years but I think is no longer available. If you want the pdf list, six pages, PM me your email address and I'll send it to you. FWIW, C1290 does not show on my 2014 Green service manual.
i got a VSS fault code yesterday when i started my new 2020 f3-limited. i think the battery was low , because i was messing around with the menu's in the display and the bike wasnt running,, the battery's lose that much power when its not running, and playing with the menu's ..
