Fan Shroud... Is this thing doing me any good?
That is a Fan Can sold by one of our vendors. It is used to direct the air flow down and out the bottom rather than out the side on your right foot.
Here's what you do..!!
take it off and find out..:roflblack::roflblack: Bet it will be hotter but have to say spyderpops has a better mouse trap...:thumbup:
You have to add the cover to the opening from Spyderpop and also remove bottom plate on the inside. I have that done on my ride and have no problem with heat on my feet. In fact when it gets cold here in the mid west we need a little heat. I asked ISCI to make the fan can with a door that could be opened in cold weather. Bob
View attachment 92314Is this thing doing me any good?
I can't say from the pic. But from the looks of it may not. What I did was the put a grill on the open part of the radiator body panel, it's a spider web with spider on it. To cool the hot air is to mix it with cooler air. The grill causes the hot air flow to break up and mix with cool out side air faster. The MISSING AIR DAM by Spyderpops helps to move more air through the radiator is the air coming out of radiator is somewhat cooler.
Mike
