Lastchance
So I bought an F3 about 3 weeks ago, never even saw one up close a month ago, did some research here and a few other places looked good to me and I needed something with reverse. Now don't get me wrong I think it's runs perfect,shifting is great, neutral a little tough to find at times but that's probably I just need practice, no twitchy corners any more but steering seems a bit tough or hard push pull through long corners. After being here for a while now I have started checking some things I've read about, (Belt Tension) bought a tension gauge not tight enough, (Belt Alignment) I could see that was off, adjusted both, now the (Wheel Alignment) it goes straight down the road no wandering, no left or right pull, so i figured they got that right, (Wrong) I have a rotary laser shows a straight line on floor ceiling walls or anything in between, set line square to the rear wheel "rim" line equal at the front and rear of rim at axle height, went to the front wheel same measurements at same height showed 1/8 toe out, went to the other side did the same it also showed 1/8 toe out, I can say the front end is squared to the rear now if it just had toe in instead of out it would probably go through those corners a bit easier. ( Quality Control ) I don't think so and this doesn't happen in shipping unless they are dropping crates from 30 feet.
