I've got the same one, although I didn't add the dash kit and opted for the Metallic Silver F3 (it's really metal flake). I chickened out and had a pro apply it as I watched, It's much heavier than the wraps I've seen, so I wouldn't hesitate to do one myself now. It really sets off the tank, and does a good job protecting it. I was starting to get scratches from carrying my camera case on my chest riding double.
How do you keep from screwing it up? If I mess it up does it come off easy???????:yikes:
it's not that hard to get straight, Pirate. A little mark on the centre of your gas cap and one on the centre of your seat helps. Plus, and I/you would have to confirm the following, but you can usually spray a water & detergent mix on the tank just before applying decals. That gives you a bit of time and the ability to slide the decal before the glue bites. This would have to be confirmed with Pete though, as I'm not sure if it would work with these.
EDIT - forget I said that....the tank protector has to go on "dry" as the adhesive is "quite aggressive". If you get on to the Wrapmyspyder site, Pete has instructions for installation for the tank protector that include his simple hinge system using masking tape. If I can do it, you'll have no problems.
You must either have a really, really low chest, or you are really, really short, Railwhale :roflblack:
Tank protector does not protect where needed. On the sides where your thighs will rub. Might not be able to tell since your area is all red but when the tank is black you can soon see the rub area.
We are working on a knee area protector for the sides of the F3 that will match the same theme as our current dash products. We will keep you up to date on the website and facebook page. Let's just say... "Coming soon"
RTL is a luxury cruiser, the F3L is the Italian Sports car!I may have to look into the tank wrap myself. Haven't made the decision yet, but heading to test drive the F3 Limited. Currently on a 2014 RTL. How do they compare? Hope full to get some feedback from those who went from the RT to the F3. Lamont, I know you have. Thoughts? I appreciate any help in the decision making. Wife and I are long haul trip takers.
RT
