F3 Passenger Sensor and one piece aftermarket seats
LifeLongRider
Found a few threads on the passenger sensor but can't seem to get an answer about this. I'm considering a one-piece Ultimate seat but am worried how it may affect the passenger sensor. The Ultimate instructions simply show to remove the seat lock pin from the OEM seat and reinstall on the Ultimate seat - but without the spring. Sure don't want the sensor to be depressed permanently but would like it work normally with a passenger. This would probably apply to other aftermarket one-piece seats as well. Anyone have knowledge about this?
I had to put a cover over the pax seat button to keep it from being pressed with just a bag strapped on the seat. I could take the cover off if I wanted the nanny to detect a passenger.
Been told it would throw fault codes if you put a switch in the wires and turned the switch off.
I was told awhile back that if you travel solo and carry a bag on the passenger seat you could remove the cover and take out the plunger. Never tried it but check around.
In answer to my original post, I received the following directly from Ultimate Seats:
"Our seat base pan has a clearance hole that sits around the sensor
and the seat foam does not touch the sensor until the passenger weight
depresses it."
I would hope that the other after-market brands do the same.
What exactly does the RT/F3 passenger seat switch do, anyway? I've heard various answers like it increases power or enables the passenger airbag (kind of doubting that one). Does it matter if a bag engages the switch?
There is no passenger airbag. The switch changes the brake bias (front to back) primarily and adjusts how the nanny reacts.
