My 2019 F3 Limited trunk lid will not consistently shut correctly. The two fingers at the back of the lid often miss the two slots they are to go into as I shut the lid. Is there some sort of alignment I can make? I know that there is an aftermarket "fix" which involves a shim that is made to fix this issue. However, I'm wanting to believe that the trunk was designed to be shut without having to slowly lower the lid while placing your hands on the back corners to ensure the fingers are engaged.
Poasttown
Poasttown
