F3 idler pulley on an RT
Devious56
Well, I don't really know how to do this, because to do it right will take a while but, here goes. I just got back from the first ride on my 2015 RT Limited with the BRP belt idler kit and Doc Humphreys adapter kit. I was a little concerned about the installation as I had to remove my Smooth Spyder belt tensioner, and will admit that doing that was harder than installing the new set up. I think the hardest part of the whole installation was pushing down on the new tensioner to get it flat and the bolt holes lined up so the bolts would go into the holes. When everything was lined up, it was pretty easy. Doc even provides the recommended thread locker in his kit. I was also worried that I would have to adjust my belt but that too was wrong, I didn't touch it. I did check the tension and it was 180 # with the tire off the ground, and 240 # with the tire on the ground. I was using a Krikit !!, and wish I knew how to convert the Krikit reading into foot pounds or Neutons. That's it for the installation. My wife just informed me that lunch was ready, so there will be a slight break before I get to my ride, hang onto your hat.......David VonStein
Now that my tummy's full, let's see how the ride went: I live out in the country, and while putting on my helmet and gloves, I let my Spyder warm up and wondered exactly what I was going to experience. I had the Smooth Spyder belt tensioner installed shortly after I got my Spyder, and was very happy with the smoothness of the ride it gave me. I had very little belt slap since having it installed, but, there was times when it did show up, and most recently when the tack came down thru 4,500 rpm decelerating it would really shake things. I rode a couple of miles, headed for the closest highway, and run it up to the speed limit, 65 mph. Pleasantly surprised, my ride was never this smooth. Keep in mind that this is a motorcycle, a mechanical device, but now it is smooth as silk. I still had it in my head, that I was going to have to adjust the belt, from what little I know, the 240# Krikit reading was on the high side. Wrong again. Now I must ask you not to be too hard on me, but I wanted answers. I went thru the gears, up to 7,500 rpm, no vibration, NO belt slap. I'd roll off the throttle, no belt slap.I was in awe! I went up to 100 mph in 5th gear, smooth as silk, 105 in 6th gear, I was in heaven. Accelerating, and decelerating, absolutely no belt slap. I did get a little vibration, from time to time, but it was more like a buzzing than an actual vibration. Like I said, I think my belt is a bit tight, but, it is tracking perfectly, 1.5 mm off the pulley flange, I am not going to mess with it! I hope I have covered everything, and if not, I'll be glad to answer any questions you might have.. As one of the testers we were asked to write our opinions of Doc's installation kit, and this is mine, as honestly as I could write it, I hope I've up held my end of the barging. I know that Kenny Butler is one hell of a mechanic and an all around nice guy, and I am waiting to see what he has to say. Everyone have a Happy Thanksgiving, and I honestly hope that your experience is as good as mine. I am impressed, it was easy to install, and performs as advertised. I think instead of calling it a belt tensioner, I would call it a harmonic dampener. .....//David VonStein
I have to add, that my testing was done solo, as my wife was getting stuff done for Thanksgiving. But, most of my riding is done double, so I am anxious to see how things go with my wife on the back. I don't expect things to be much different, but I will post again after the next ride.
David
Should i wait?
I was just about to go to work installing the smoothspyder on my 15 rtl thats been sitting around since summer. Should i wait? What made you want to switch to the new brp ?
Thanks for the review! :clap:
Question: What does BRP's belt tensioner cost, and do you have the part number for it?
(Okay: TWO questions! :D)
219800412 Idler Belt kit
#34.99 and cost me $15.00 shipping from Pit Bull Power Sports in Springfield, Mo.
I think Lamont has one very similar.
David,
Why did you take the smoothspyder off? I intend On installing Doc's kit but plan on keeping the smoothspyder on as well. Is the smoothspyder in the way?
My theory is that the smoothspyder will keep tension when letting off the throttle, and the BRP tensioner will reduce vibes while accelerating/cruising.
Take Care,
Louie
David,
Take Care,
Louie
The BRP one is all that is needed. It works absolutely great on my F3 Ltd.
Cruzr Joe
Cruzr Joe
I have to go with Joe, A belt tensioner isn't the answer, the idler pulley dampens the harmonics . I did everthing I could on my ride today, to induce belt slap and vibration. I honestly feel, it is the fact that the pulley is on the top run of the belt that is the answer. My Smooth Spyder tensioner was set at 12 pounds and put a lot more tension on the belt than the idler pulley does, and yet it didn't do the job that BRP's did. It is your trike, and it isn't that much of a job to remove your Smooth Spyder, why not try the BRP one by it's self and see what happens? All you have to loose is a little bit of time. Who knows, you may find you don't need the heavier tensioner. If you do need it, you can still put it on.
Good luck in what ever you choose, I hope you wind up as happy with your trike as I am with mine. I will say this, what led me to trying the current set up is that I had a significant bit of belt slap, at 4500 rpm, when I let off the throttle, that was with the Smooth Spyder one, this morning I had none, from idle to 7,000 rpm.
David
:clap: Thanks! :thumbup:
Before I order anything; I'm going to wait, and see what Lamont's looks like!
Bob I think he did a video about it on his site and should have it ready soon. Ask him about it.
Here is a link to his video for the idler pulley, but I don't think he is doing the TR adapter (yet).
[video]http://www.lamonstergarage.com/news/f3-idler-kit-install/[/video]
David
Happy Thanksgiving.
Belt Tensioner / Harmonic dampner.
Well I got it installed and now wait till snow is gone so I can test ride it. Install was smooth after watching Doc's video. Thanks Doc.
I did mine today!!!!!!!!
David
Well I put one on my 2010 RTSE5 today and will most likely remove it tomorrow!!!!!!!
The thing screams like I have a turbo, so loud I can hear it with my hearing aids turned OFF!!!!!!!!!!!!
  • :banghead:
  • :banghead:
That is strange. I did one with a ribbed belt 3 days ago and you could hardly hear it. I am assuming you have checked the alignment?
Part Refund
Spoke to Kathy and if you want to take it off and send it back, we will refund the part even though we state there is some noise due to the ribbed belt.
Alignment
Yea, the alignment is perfect, I used the BRP unit and as you know it is not the best designed or built available.
When I can afford it I will probably purchase one of your units.
OK, Timeless, couple of things you can do:
Send us an email to: http://dochumphreys.wixsite.com/roadster/contact
1. Give us the email address that you used when ordering the kit so that we can reference your order. This will also establish that you are having problems and the date.
2. Make sure you were moving forward when you stopped where you are. The alignment of the belt will not be accurate if you have backed up. To get a correct track of where the belt rydes when you are ryding, you have to do this. Double check that the bracket alignment is aligned with the belt. It is possible to center the pulley on the belt and have it slightly tweaked so the front of the bracket and the back of the bracket are not even with the belt. This will cause the pulley to slightly skip since it is angled on the belt. A small block of wood against the belt should allow you to measure from the wood to the front and back of the brackets to make sure it is straight.
3. After verifying the correct alignment, make sure you test it with the tupperwear back on. The sound deadening panels substantially reduces the buzzing noise.
4. Run it for a couple of weeks. Since you have sent us the email (above), we have it on file that you are having problems and we will honor your return regardless. It may seat in and the noise may reduce. Or it may not.
If none of this helps, then you will have 2 choices; you can return our damper and live with the vibration or if your belt (2008) is fairly old, check on replacing it with a newer style belt that is smooth on the outside.
We want to make you happy.
