F3 Break in
Doug
As per the manual, it says after break-in period 1000km (600mi), your vehicle should be inspected by an can-Am authorized dealer, my dealer says he is not aware of this, what is correct.
I had thought it was a 600 Break-In then the 1st maint at 3000 miles. Although they
they say check per the maint schedule... which is at that 3000 miles. (So you could very
well look that as having them look at it)
I'll be checking it all anyway, especially the wheel lugs, oil levels, water.... look for any
leaks of any kind around the engine area. I may also do an oil change come 1000m just
for grins.
Not sure..!!
The 1330ACE engines had the first service at 3,000 miles and the 998's at 600. Have not seen the manual but from postings here they are going in at 3,000. Check over things you should do anyway but you could have the dealer hookup to buds for a readout and check it over but doubt it will be cheap....:dontknow:
