Extended transmission filter cover
Dallphin
I bought a used 2011 rt-s recently and I am pretty sure it does not have the extended transmission filter. Anyone know where i can buy the metal cover so i can use the newer extended transmission filters? thanks
They stopped selling the small filters in 2013 and gave away the covers with all new filters for a long time. You will have to order one from BRP Parts.
This also means your bike has not had an oil change in a long time.
You don't really need the extended transmission filter. The only filters that ever gave anyone trouble were the very poor quality BRP factory filters. Why BRP reinvented the wheel when all they needed to do was produce a quality filter in the same dimension is hard to understand. They could have just contracted with one of the aftermarket companies that were already producing quality, trouble free filters. But I digress.
I sell a lot of filter kits and I still have a good number of customers using the original filter. I do not know of any instance of anyone having a problem with these smaller filters. As long as a filter flows enough clean oil, a bigger filter is just a waste of time (and in this case, money).
Not only does the original filter size work well, it is less expensive because this filter is used by a great number of other vehicles. It's all about volume.
I am not saying there is anything wrong with moving to the larger filter. I'm just saying it is not necessary. A good quality original filter size will do just as well.
Try this....
If dealer has no stock try cheapcycleparts.com. They are well stocked on oem parts...:thumbup: there may also be somevonline at ebay etc....
