Exhaust wrap
Noral
We have a 2010 rss se5, what type of exhaust wrap is best also which width and what length would I need to order and from whom.:dontknow:Thanks
I've used both the 2" and the 1". The 2" is a quicker wrap but the 1" does a better job (going around bends and getting a tight wrap). I like the carbon impregnated stuff but I'd say any good quality product will do just fine.
25 feet of the 2" or 50 feet of the 1" is more than enough to do the job.
I wrap from where the pipe comes out of the head to the Y connection with both the front and the rear exhaust. It makes a difference both in the heat you feel and exhaust noise.
I've had mine on for 3 years and it's still good. It takes some patience and some time but it's well worth the effort. Make sure each turn around the pipe is tight, lays flat, and you have about 1/2" overlap.
You can spray paint it with high temp paint once you get it on. Just be sure to mask behind the pipe. Of course the pipes are much easier to wrap if you take them off but I am not sure that would make the overall project less work.
