Exhaust Question (Yes I know...)
McLlyr
I've looked and can't find an answer to my question, do slip on exhausts significantly change the sound? I'm not interested in popping wheelies 😁 just improve the sound. Thanks
Simply removing your cat and installing a cat delete will dramatically change the sound of your exhaust.
I have the RLS Exhaust cat delete with resonator and stock muffler. The sound is a smoother, throatier purr, without increasing the sound level. I am very pleased.
Call Rick at RLS - he makes them and can tell you what sound to expect from what component.
My 2015 Spyder F3 didn't sound too good when it broke down today. See my thread.:D
Yeah, but you didn't use a Slip-on exhaust to make it sound like THAT, did you?! :shocked: See my & other's answers in your thread. Good Luck! :thumbup:
Back to Mc Llyr's question, as other's have already suggested, the short answer to that question is YES, they can! :ohyea:
And expanding on that a little, an RLS (or any Cat Delete/Cat Eliminator for that matter) will generally also help add a little more 'mid-range' grunt, albeit possibly at the expense of losing a little 'low range' torque (the RLS Cat Deletes have largely resolved that tho! ;) ) so you've got TWO basically viable Options Mc Llyr, plus one more 'extension option' to change the sound.
  1. You can fit a Cat Delete with the Stock Muffler;
  2. you can fit an alternative Muffler in place of the Stock Unit, ie, your original 'Slip-on' option (IF you can find or make anything that'll actually Fit); or as the extension option,
  3. you can do both - Fit a Cat Delete AND an a/mkt Muffler Replacement!
And luckily for you, RLS Exhausts IS a Sponsor here, so well worth supporting.... but IIRC he might be waiting on materials to re-stock right now, so give him a call! Click on the RLS Exhaust.com logo on the Home Page for contact details! :thumbup:
:cheers:
:cheers:
Thanks!
You can make that thing just as loud as you want!! I would take baby steps, one thing at a time or you will be another one of those people that are on here trying to sell a pipe that they don't like!!:thumbup: Good luck, hope you find that perfect sound your looking for!!!
Thanks
A recent topic suggested a $20 mod. Retain the oem converter, and have a tail pipe fabricated at a local muffler shop. Simply remove the entire muffler and use the cat as a muffler.
Simple, easy, and minimal cost if not content with it.
