exhaust pipe color
frenchek
I have a 2013 rt with no heat issues ,have about 3400 miles on it with several long trips with back to back fill ups. here is the question for you motor head guys: does the color of the exhaust pipes indicate if the bike is running lean or not. I know on a older Harley I had the exhaust was turning blue and the tech adjusted the fuel mixture. I took all the tubberware off today to check things out and noticed the pipes were the original color. the other thing that I noticed was that the gas tank had some insulation on it--I don't recall any body mentioning that. I was going to wrap the pipes but I think all i'm going to do is add a belly fan and cowl vents over the vents under the mirrors to exit the warm air.
