evo sway bar bushings
wyliec
Where would you purchase the bushings since evoluzione is no longer in business and the oem bushings won't fit?
Give the OEM bushings another try. I had to use an OEM bushing on my 2009 GS temporarily until I could get a replacement from evoluzione. It fit.
Would the OEM bushings be okay to leave on the EVO bar permanently?
If this is all you have, give it a try. Keep an eye on them to see any deterioration. If they fall out, you will know it because there will be a loud noise when you go over a bump. I had this condition on an oversized vehicle I once owned. In that case it was a very loud noise. New bushings soved the problem.
