SpyderDuck
Going down I-40 yesterday at about 70 mph, and suddenly Clyde goes into limp home mode, after about 30 miles. VSS fault. DPS fault. ABS fault. EBD fault. Just about every light on the panel was on. You name it, it had a fault. :gaah:
We pulled over, and I turned the bike off and checked the relays to make sure none were loose. Took the key out and away from the bike for a little while. Then we restarted, and things looked normal for another mile or two, and it all started again. Again, we pulled over, and removed the key again. Upon starting again, I only went about 20 feet before it all fell apart again. Limp mode only allowed less than 20 mph, or Clyde sounded like he was coughing up a hairball. Speaking of hair, it was a pretty hairy ride on the interstate doing only 20! :yikes:
We had finally almost reached an exit ramp, so we pulled over at a service station and checked relays and oil. We didn't see anything amiss. Ken picked me up with his trailer and took us home, and he will carry Clyde to the dealer this week (big thanks to Ken - he's da man!). I guess we'll find out what happened.
On the bright side, I did get to spend most of the day with Catniption
