Error codes
Codes...
Not sure but I use the spydercode app with which you can look up codes with explanations and suggestions. Must be other places and those in the know will chime in ... :thumbup:[
The iPhone / Android App "spyderCodes" is no longer available.
Online you can find the codes here: https://drive.google.com/file/d/0B-NsxYsZx2HmdDBtVzJ5YXRnY1k/view?usp=sharing
Refer to the Ryker Series Repair and Maintenance Manual for codes and troubleshooting tips.. You can buy the manual as a PDF here: https://brpmanuals.com/canam-
An example from the Spyder Manual:
[table="width: 500"]
[tr]
[td]PCODE[/td]
[td]MODULE[/td]
[td]DESCRIPTION[/td]
[td]CAUSE[/td]
[td]ACTION[/td]
[/tr]
[tr]
[td]P08xx[/td]
[td]ECM[/td]
[td]Pre-starting relay short circuit to ground[/td]
[td]Blown fuse, damaged or disconnected relay ...[/td]
[td]Check fuse. Disconnect prestarting relay ...[/td]
[/tr]
[/table]
