Error codes on 2014 RTs
spyderwoman
Need a little help , has anyone had the engine light come on and we pulled the error codes up and got codes U0101 and U0303 ? Checked the codes and came up with ECM ? Ok where is the ECM located ? Thanks for any help I can get before taking to the shop .
ECU !!!!!!
Need a little help , has anyone had the engine light come on and we pulled the error codes up and got codes U0101 I don't know if you are religious or not ? . But if you are out of Warranty,.... you should PRAY :pray::pray::pray: .. that it isn't the ECU .... good luck ...Mike :thumbup:
