ENGINE HEAT RESOLUTION QUESTION
Speedy Spyder
Has anyone installed the Motul "m0-Cool" Engine Coolant Additive to reduce engine operating temperatures?
Motul Factory claims up to 30F lower engine temperatures using this additive with stock coolant.
Wondering if the product is all hype or if it really works.....
We'll see
there are many such products and claims..interested in seeing how it works for you. Because of our climate I just run 75% water 25% coolant with water wetter for lubrication puposes..Motul is a great product hope it hold true...!! :dontknow:
If your bike is not overheating, IE operating at the thermostat and fan turn on set points, the better coolant will do nothing for you. The temp will still be controlled by the thermostat and fan controller. Very few Spyders actually have engine overheating problems. They have problems with exhaust heat under the tupperware.
My my bike isn't overheating, my dealer told me about Mo coolant additive. I recently installed cat by-pass so far the heating has reduced a great bit. .
Thanks for the info.
