OverHillAndDale
:yes:
I was ready to melt down my Aluma trailer and sell it for scrap. The lights worked fine if I hooked them up individually to a 12 volt battery, but not when I connected through the BRP connector. I discovered something curious - resistance to the ground changed when I put on the turn signals or brake. Perhaps this is how the bike goes in to trailer mode for the 2014 on up which don't have a trailer setting through the dashboard? At any rate, all the lights worked unless I hooked up the running lights, then it all went straight to hell.
At any rate I bought a Big Bike Parts adapter. Today I disassembled the back end of the bike, removed the seat, then removed all last components of the BRP hitch adapter. The BBP was easy to install EXCEPT for all the disassembly of the bike and running a power and ground all the way to the battery, which is in the frunk on the 2014s. It is a 5 pin adapter, so I bought and installed a 5 pin flat connector. This is better suited to my trailer anyway since it has separate brake and turn signal lights. It separates the bike power from the trailer power via solid state (I think) relays.
At any rate, it worked beautifully. The trailer LEDs work as they're supposed to, so I was able to test-pull the trailer for the first time today.
I don't know if the BRP adapter only works well with BRP trailers or if my unit was defective, but since I'm towing a non-BRP trailer and since I installed the adapter myself, I suspect I won't get anywhere trying to get BRP to warrant the adapter.
Thanks for everyone who offered advice (and sympathy) from my previous posts.
