elka shock install
Freezedryman
Is there a set ride height for proper weight distribution on a 2011 RT-S ? Installed Elka shocks and picked up 2" in ride height. I adjusted the shocks so that my ride height was 1" higher than stock. I have not rode the machine since install due to weather.
Try to have the A arms parallel to the ground. Handling is affected if you raise the front end. Alignment, too! Joe
