Electrical Help
Sccar
Greetings all,
I am hooking up my shark audio system and did not want to hook it up directly to the battery to avoid it being on all the time. Would it be ok to connect it to the accessory circuit behind the storage compartment so it will only be on with the key?
Thank you.
Sure. ..
As long as it is,the switched side. There is a constant as well. Also check the amperage...:thumbup:
I think they are all switched. Shark manual says fuse rating is 5 Ag, specs on the website says 10A. Fuse for the accessories on the spyder is 10A
