MarkLawson
RT-S PE#0031
Many folks have commented on how difficult it is to remove/install that ground bolt next to the fuse panel under the seat. BRP used a 6mm bolt with a self locking (nylon) nut on the bottom side. To get a wrench on that nut is very difficult. I finally removed the fuse panel completely to get the room to remove the nut. I was at Home Depot and decided that I would cut threads into that hole the bolt runs through & bought both 7mm & 8mm bolts & took them home. When I looked, I found that BRP had already threaded that hole & that the 8mm bolt fit. I did have to drill out the hole on the end of the cable going to the negative pole of the battery & also replace the connector to a larger one on the wire that runs to the fuel tank to fit on the larger bolt.
Now, when I want to ground something at that point, it is easy.
