900Dave
Limp Home & ABS Fault.
I managed to get my ST to throw all of these faults this morning with out leaving the garage. :banghead:
I had just watched a video on belt tension & alignment. So I do not have a cricket but figured I would do the belt alignment since my belt has been tight against the inside of the sprocket for a while now. So I jacked up the rear loosened the axle bolts started the Spyder and put it in first gear. I barely had to touch the adjustment bolt and the belt came right to center. That was easy, nope! Went to shut it off and had the EBD fault. When started back up the other faults showed up. It is raining here so I did not take it on the road. I did run it front and back in the garage pressing the brakes hard each time to stop and all the fault codes and check engine light cleared.
So should it be good now? Or did I just screw up my weekend ride? Does it have to go back to the dealer?:dontknow: When the rain stops I will of course take it out for a few miles and see what happens.
