Easy way to check master cylinder on RS
Orange monster
Just thought I would pass on an easy way I found to check the master cylinder on the RS and RS-S models today. You can take your iPhone or similar device and slide it in the slot on the right side of the bike and take a picture of it. This requires no plastic panel removal and literally takes 2 minutes at most. Here are my results.
Just thought I would pass on an easy way I found to check the master cylinder on the RS and RS-S models today. You can take your iPhone or similar device and slide it in the slot on the right side of the bike and take a picture of it. This requires not plastic removal and literally takes 2 minutes at most. Here are my results.
I use this trick all the time for model # notes or part # especially if you can't get the angle to read them plus you can expand them if needed to read plus they can be saved without notes to lose
2009 rs sm5
