Easy Grip Puppy Installation
ABN350F
First soak the size SMALL grip puppies in hot water. Pour dishwashing liquid inside one of the grip puppies and smear some on the original grip.
Next -- Insert your index finger and middle finger into the grip puppy -- pushing the puppy up to your knuckles.
Spread your fingers apart and insert the open end of the grip puppy over the stock grip.
Remove your fingers from the grip puppy. Then insert your index finger into the puppy and between the puppy and stock grip.
In a clock wise motion rotate your index finger around the stock grip while keeping your index finger between the grip puppy and the stock grip and slightly push forward.
The grip puppy will go on very easily.
Repeat on the other side of the handle bar --
5 minutes max to put both on.
Hope this method helps!
Ya thanks,
That should help I ripped the first one I tried to put on. Now I just have one but will order some more. And try your method.
Mike:D
Bless you my son. Your faq made this so easy. Ruined my first pair trying to put them on. This should be how the instructions read. :2thumbs:
I am. Born and raised in Flarda. Have four beautiful grandkids. Not to mention that I'm left handed too. :D
Yep, in someways it's a curse being a Lefty, Opening a loaf of bread with those wire ties drives me nuts. [you won't find too many left handed wire splicers]
When i was i kid in Brooklyn playing stick ball all my friends were rightys they wouldn't let me pitch to them.
The ball would curve into them.:shocked:
