Anyone go from a ST to an F 3 ? My question is any problem with the width of your foot positioning ?
Test rode an F 3 and noticed quite a difference in foot placement. I'm guessing the bigger motor requires the added distance in between your feet. Any comments ? Thanks.
I had an ST and just went to a F3-L on August 25th. The positioning of your feet are totally different between the 2. With the ST your feet are back under you farther and where the bike is narrower verses the F3 where they are more in front toward the wider part of the bike. So yes it is a little wider but you get used to it real quick. Also were you able to have the spyder set up for you? That would also make a difference on how it felt to you. If you had your legs stretched way out in front that would make it feel a lot wider....if that makes sense.
I love the F3 and I am so glad I had the chance to make the switch. The cornering is so much easier, faster, and smoother. I just love everything about the F3!! It is like night and day for me. The one thing that I do want to get eventually is Lamonster's RIP floorboards. That way I will be able to move my feet into different positions on longer rides.
If you have back problems you may suffering with you feet stuck out in the birthing position. There have been post in the past on this. Good luck. And no the u fit will not slide back far enough with out modification.
:riding:
My wife did just that. She loves the new foot position. She said that she finds it way more comfortable and she is only 5' 4" tall. She loves her F3 more than her RS & STL combined.
I prefer the Seal Floorboards. Allows unlimited foot positioning! Also allows for standing up to stretch.
Ride seemed rougher also (two up).
