Does the ACE 1330 engine contain a Slipper Clutch?
Leland
I would like to know if the ACE 1330 engine contains a slipper clutch, or is BRP using Nanny to watch for wheel skid on compression braking. I read in the owner's manual that Nanny may increase (open) the throttle to prevent skidding on sudden throttle release. The owner's manual did not give any further details. I suspect that the engine does not have a slipper clutch. The lack of a slipper clutch could allow the engine to overrev during an accidental downshift.
Any thoughts on this subject?
I believe it is all hydraulic and computer controlled to the point you cannot overrev on the downshift. It just won't let you shift.
Doc,
That makes perfect sense for the SE6. Thank you.
How about the manual tranny?
High power (compression) 4 stroke 2 wheelers use a slipper clutch to prevent wheel hop on downshifting, how does the manual tranny Spyder handle this problem. I have not looked at the parts list for this engine to ascertain the existence of a slipper clutch. Do we have any readers out there that have disassembled a ACE 1330?
yes and no
The SE5 and SE6 have slipper clutch. On the SE5's you had to be above 4,000 rpm so as not to have the clutch unlock. That is how you go slow in parking lots. I saw an SE5 RT with the clutch basket burned up as the user had pulled a trailer at low speeds at too low an rpm. Not sure on the SE6 where the unlock point is. Someone will have to tell on the SE6. Should be in the unread owners manual.
As far as I can tell, there is no true modern slipper clutch to eliminate engine braking that I can sense when riding.
Yes the SE does have a semi automatic design for acceleration.
You can shift up and down, sounding pretty much like a modern supercar, including off throttle bang when you get back in it.
Slipper Clutch details: Slipper Clutches on motorcycles.
Thanks Deer Slayer: I understand what you're explaining, but I don't think we're talking about the same thing. What I'm talking about is a clutch that allows the drive wheel to spin freely during hard engine compression braking, giving the rear drive wheel a place to release its energy. Without this feature the drive wheel will hop or skip off the pavement. This was first discovered when super bikes went from 2 cycle to 4 cycle engines. Many accidents occurred until engineers designed a sprag clutch system to release this energy.
Here is a good article that describes Slipper Clutches on motorcycles
How Slipper Clutches work: Video
Here is a nice video that tells the Slipper Clutch story.
[FONT=&quot]
[/FONT]
Not sure it applies, but both our F3 and RT will occasionally "Bang" into first gear. I think it's a software glitch. It usually occurs when you are going down a slight incline in second gear and suddenly it's like the computer forgets what it's doing, then decides to freewheel for a few seconds, them "bam" it drops it first gear. By how hard it hits, I doubt that it has a slipper clutch irrespective of the hydraulic system.
I was always cautioned to get the clutches engaged quickly when starting off. Consistent low RPM's when taking off could possibly prematurely wear the clutch. It needs to lock up tight. And that is another reason I don't think that it has slipping clutch. I think they tried to take care of what you are talking about by software means and setting parameters for downshifting.
Star Motorcycles had a nice video showing how their new design had a slipper clutch built into the main clutch, perhaps BRP has incorporated this type of feature into the new ACE1330 engine?
I had a 2012RT and now have a 2016 F3. I do not see the need for a slipper clutch. Neither of my 2 wheelers have them either.
Deerslayer is referring to the engagement clutch used in the "SE" transmissions.
The sE-5 has a centrifugal system: it's a "slipper" only in that it takes a couple of hundred rpm for it to fully engage and lock-up. This process seems to occur in the 3,200 to 3,500 rpm range...
The SE-6 is a whole different animal: it engages and locks up hydraulically. This all seems to occur down around 2,000 rpm.
Never had either spyder hop or skip the rear tire on deceleration.
No slipper clutch. Really no need for it on a Spyder. If you wish to confirm for yourself take a look at the exploded parts view on BRP's website.
